V6 Cost Sheet Not Diplaying all components
Aaron Fried
Company Name: True Wood Design
Post by Aaron Fried »
When I pull up a cost sheet from custom layout, the "sheet stock" summary and the "doors" are not displaying on the list. I always used the cost sheet to generate estimates on my jobs and until V6 everything worked out great. Is there something I'm doing wrong or is this a bug?
Thanks for the help.
Aaron
Aaron Fried
http://www.truewoods.com
MSI K9N2 PlatinumMoBo / XPPro SP3 / AMD Phenom 9500 2.2 MHz Quad Core / 4GB, 333MHz / 2xGeForce 8500 GT512MB
BEN HOLM
Re: V6 Cost Sheet Not Diplaying all components
Post by BEN HOLM »
Yea im having a similar problem. Everything shows up except my drawer slides. Shows up in my buy list but not the cost sheet.
Dell Precision M6400
Core 2 Duo T9600 2.8GHz
4GB Ram
NVIDIA Quadro FX 2700M (6.14.11.9562)
Windows XP Pro 32bit
Tom Nienow
Company Name: Nienow Woodwork
Post by Tom Nienow »
My cost sheets come up with most hinges and some drawer slides missing, haven't gone through the sheet/board stock manually to see if that's an issue
Aaron Fried
I don't see sheet stock at all, is there something I can do different?
Aaron Fried
Aaron,
Post your job so we can nest it and see what happens.
Aaron Fried
Well it won't allow me to post .twd file and the actual job file exceeds the size limit.
Here is a picture of the job, I wonder if bringing my cabs in from the old version has something to do with it. I hate to have to start over but I'll try building on the V6 library and see if I still have an issue.
Aaron Fried
Company Name: Halls Edge Inc
Post by Josh Rayburn »
Aaron,
You can zip a .twd file to post it.
It's generally better to post the zipped job (.hsf) file though because there's nothing we can do with a .twd except nest it and print labels from control nesting. Only Thermwood folks can extract the actual job from the .twd file.
Aaron Fried
Here is the file.
Layout01.zip
(5.62 MiB) Downloaded 1260 times
Aaron Fried
Aaron Fried
Just a note: I added all of the same cabinets to a new job in batch and all the components listed fine in cost sheet, nesting, and buy list. Strange.
Aaron Fried
Aaron
I'm getting a funky cut list from your file, too.
The quantity for the 3/4 Birch 1s is showing as -2147483647 which is definitely not correct. You can see the doors on the cutlist, which is because you've got them applied as 'build in house' so they won't show up anywhere but on the cutlist... if I remember that right.
Don't know what's causing the birch to be off....
Something to do with that Birch I think....
I tried to nest your job and got only blank screen. Deleted the side-by-side fridge (which is known to be problematic) and no change.
Then changed all the 3/4 birch 1s material to one of my 3/4" materials I use all the time. That seemed to do the trick.
I now get a proper cutlist (I think, I didn't look too close at the job)
See if changing that material helps you to get the sheet count from the cutlist - as far as the hardware items, the cost sheet seems to be working, I just don't know how many you're really supposed to have.
Aaron Fried
FIXED: Thanks, changed the sheet stock and all seems ok now.
Aaron Fried
Ryan Callahan
Post by Ryan Callahan »
Aaron,
I see that you said it is fixed based on Josh's advice, great.
I found that there is a problem with the ASSEMBLY cabinet over the sink that is causing the issue. If you take this to the Cabinet Editor, select the cabinet by double clicking the crown molding (high-lite the cabinet green), then remove Part Editor cuts. Not return to the room and all is well with the cut-list.
I am unsure as to why this is the case, but I thought that I would let you know this solution as well.
If there is a Part Editor cut on this cabinet, then maybe something there is what is causing the problem.
Ryan Callahan
Thermwood
