Unable to find installed furniture library
I am attempting to install the "Manchester Collection" from the available free cabinet libraries. I download the .exe file to my desktop, installed it, opened up eCabinets and am unable to locate any of the cabinets to place in a room I am designing....?
- Ryan Callahan
Re: Unable to find installed furniture library
Reed,
I am guessing that this install will need updated. I would check in the OLD 5.2 install location for your machine. By default, that should be as follows:
C:\Program Files\Thermwood\eCabinet Systems\Cabinets
Just a guess. I can check deeper if need be.
Ryan Callahan
Thermwood
Thermwood
I recently purchased a new computer so eCabinets 6.2 is a fresh install, and as you know the cabinets folder is not where it used to be -- in fact, I do not know where it is...
Regardless, when I am in eCabinets, I want to load files from the free Furniture Library that have been installed. So, not only do I not know where it has been installed, I am unable to load it into the program...
Help....
Thank you.
Help....
Thank you.
James Newman
Hello Reed,
There is an issue with the Furniture Collection Libraries that we just found. It seems to be an install error. The programmers will be looking into this.
All of the Cabinet Libraries download and install in the correct location, so currently any of these can be used.
Sorry for the inconvenience.
Mark Pratt
- Company Name: Bay West Construction
Well, actually, unable to install is more like it... I've just done a clean install of version 6.2 and downloaded the frameless and full dado face framed libraries and they won't install. Instead they get most of the ay thru and stop with the following error:
Product: eCab Frameless Library 001 Installer -- Error 1334.The file 'ATL80.dll.8.0.50727.762.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E' cannot be installed because the file cannot be found in cabinet file 'Data1.cab'. This could indicate a network error, an error reading from the CD-ROM, or a problem with this package.
I've tried this on a few other lbraries and get the same error...
Any ideas?
Thanks in advance...
Mark
Any ideas?
Mark
Evan Andersen
- Company Name: Evan Andersen Woodworking
I'm having the same problem installing the free cabinet libraries, has there been any resolution to this?
www.evanandersen.com eCabinets runs great on a Bootcamped MacBook Pro, 2.4Ghz, Windows 7
Evan Andersen
BUMP..I know this thread is almost 2 years old, but I'm having the same problem, hoping someone has found the answer by now!
- Scott G Vaal
Evan,
Download and install the Microsoft Redistributable Package from the following link. Then see if you are able to install.
http://www.microsoft.com/download/en/de ... en&id=5638
George Shaw
- Company Name: Reliable Remodeling
I was having this problem as well today. Thanks for posting the fix from Microsoft.
Virgil Wilson
- Company Name: VRG CABINETS and MORE
Thanks for the fix on my downloads. I had the same problem it works great now
