Rapid Speed
Discuss Thermwood 5-axis Machinery, Controller, and Software.
Moderators: Mike Iubelt, Jason Susnjara, Clint Buechlein, Mike Iubelt, Jason Susnjara, Clint Buechlein
Luke W Clarke
Company Name: Greenbank Patterns
Rapid Speed
Post by Luke W Clarke »
When the machine goes to the XYZ postion i put in is there anyway of changing the rapid speed ?
Just dont want to get it wrong one day and run into the part :oops:
New to using a Thermwood :D
Brad McIntosh
Company Name: CNC Automation
Re: Rapid Speed
Post by Brad McIntosh »
Luke,
How are you programming - via a CAD/CAM system like Mastercam or manually with the hand-held programmer (HHP)?
Brad McIntosh
CNC Automation
Twitter: @bmcncautomation
Dennis Englert
Re: Rapid Speed
Post by Dennis Englert »
To manually affect the speed for a rapid traverse there are a couple of methods.
First, Insert a M48 command at the top of the program, then you can controll all rapid movements with the feed rate knob.
Second, locate the G00 command, the use the Tab editor (press the Tab key) to change the code to G01 and add a feedrate on the same line, such as F400. You can also use the Editor to replace all G00 commands with G01 F400.
With regards to Brads question about how are you programming. If you are using a CAD/CAM system, then you may need to update the Post Processor to include a M48 command. It's possible, you may want all of the G00 commands changed to G01, so you may be able to do that with the post processor also.
Dennis Englert
Re: Rapid Speed
Post by Ryan Hochgesang »
Luke,
To add one more note to this topic, the M48 feature will only apply if you have TWD version 4.50 +
Luke W Clarke
Re: Rapid Speed
Thanks all for your help know how to do it now :D
Sure i will be on here more asking questions :mrgreen:
Thanks again
