Printing in V6.2
Cy Rebarchak
Company Name: CDD
Printing in V6.2
Post by Cy Rebarchak »
Hi All,
I'm trying to print a line drawing of a very simple cabinet in V6 build 2. I keep getting the error below and Ecab closes without printing. This just started happening with build 2. Any ideas? I've attached the job file also.
Cy
Error Message:
AppName: ecabinets.exe AppVer: 6.0.34.0 ModName: hoops_mvo1713_vc80.dll
ModVer: 17.13.2.0 Offset: 001132a4
Pan Cab Dims.esj
Drawing trying to print.
(208.02 KiB) Downloaded 963 times
Gary Puckett
Company Name: The Woodworkery
Re: Printing in V6.2
Post by Gary Puckett »
Cy,
I just tried your cabinet and it printed out just fine on my system
FredHirsch
Post by FredHirsch »
Cy,
What is your printer make model and do you know the driver version?
Fred
Fred Hirsch
Cy Rebarchak
Company Name: CDD
Fred,
I am using a HP Officejet J6480. The driver ?? I tried printing to a .pdf and it was only successful 2 out of 6 tries. Ecab would shut down. It's only a problem when printing from the line drawing editor. The cabinet prints fine from the cab. editor.
Cy
Terry Davis
Company Name: Penn Laminates
Post by Terry Davis »
Same problem here, "ecabinet systems application has encountered a problem and needs to close" happens everytime i try to print. (HP Officejet pro K5400)
Jason Fabretti
Post by Jason Fabretti »
Same here, Mine just crashes and locks up... :wall:
Jon Dieterlen
Post by Jon Dieterlen »
I changed the print quality to draft in the printer properties. Then open the window showing the print job progress and wait until it is completely done printing the page before attempting to print another page.
A little slow, but it has worked for me.
Jon
Terry Davis
Does not matter what I set the properties to or what printer in the shop I send it to it will crash, any ideas I really need to print out drawings.
