Faceframe thickness problems
Post by Donald Thomson »
I've attached a room layout zoom-in picture of a corner base cabinet adjoining a standard base cabinet. As you notice in the picture the faceframe depictions are different thicknesses even though both cabinets are set to have 3/4" thick faceframes.
This is happening with two different corner cabinets in the same layout.
Any thoughts?
Corner cab faceframe thickness 800x388.jpg (38.22 KiB) Viewed 4347 times
Re: Faceframe thickness problems
Don,
Post your corner cabinet.
Here you go Kerry.
Corner cabinet faceframe issue.hsf
(572.02 KiB) Downloaded 351 times
Don, in Define Materials, your hickory stock is set at 15/16".
Thanks Rick,
That is what I wanted to check.
That's very interesting. I set all my faceframes to 3/4" thickness. I wonder how this one changed to 15/16" thickness. I've also had PE cuts put into cabinets that I didn't do.
Kerry, do you remember the problems I was having resizing a cabinet? Somehoe PE cuts were put in that cabinet and I had never taken it to the PE to do that. I selected the entire cabinet, removed the PE cuts and resizing worked fine.
Yesterday I went to exit eCabs after a long editing session and during the saving process you get a dialog saying how many objects are being saved. Somehow this job jumped from about 900,000 objects from the previous save up to 3,200,000 objects.
Strange behavior......Random
