Hi,
We have noticed that when our machine is trimming up an off-fall, the cutter is cutting into any parts beside the off-fall. It is cutting into the part by around 2-3mm. This spells a big problem when machining doors. Logic would suggest that I have the tool dimention set wrong but I have double checked all this and its set correct. It appears to be a programming error on control nests behalf. Has this happened to anyone else? Am I missing something?
Dale
Off-fall trimming problem
- Dale Wills
- Company Name: none
- Country: AUSTRALIA
Re: Off-fall trimming problem
Hi Dale,
If you could please, send the following files to: program@thermwood.com so that we can review:
- EXPORT from Control Nesting (Button at lower right of C.N. Screen, first next job prior to selecting)
- Actual CNC code you've run and seen issue occur with
- Cabinet/Part design file (.hsf, .esa, etc...)
Thanks!
Thanks!
This issue has been verified and is currently being worked on. Hopefully we will have an answer soon for you. Thank you for your patience.
