I lost the Appliance button in the cabinet editor. All the other buttons are there and it is still in the Ecabinets file when I look in Windows Explorer. Any one experience this?
Thanks!
Nick
Ah yes, it is there in the custom layout section. In the past I thought I had added appliances into an assembly when I was in the cabinet editor but I guess I did it in custom layout.
Thanks for setting me straight.
No problem. You may have be thinking of display objects. There is a microwave and other items in there that you may have used in the past. If you want or need one of the appliances as a display object, you do have the option to export them from a layout {File -> Export Selection}. This creates an .hsf file that you can load into the Display Part Editor re-texture and save as a display object. Then you would be able to use/load it any where you want.
