Toe Kick configuration!
Eric Garrett
- Company Name: Garrett Industrial Inc
I am trying to install a toe kick which is on the front edge of the cabinet sides and flush to the outside! I only see it butting or dato to the inside. Can I change this?
Re: Toe Kick configuration!
Hi Eric.
Welcome to the forum.
I set the toe kick construction to full dado, and then press the front toe construction parameters to go to the next window. Set the depth to the thickness of your end material. I think this will give you the look you want, but I am not sure how it would cut on a CNC
- Kerry Fullington
Eric,
You can also set your left and right toe kick construction to butt and then enter a negative left and right inset that equals the thickness of your end material.
This will not display graphically correct but will give you the correct cutlist and will machine properly.
