Hardware Hole Issue
Nat Wheatley
Hardware Hole Issue
Post by Nat Wheatley »
In making changes to a hardware hole pattern, the changes aren't showing up when I reapply the pattern to a part (in this case used for an RTA fitting). When I go back into the Hardware Hole Editor and re-open the pattern, the changes have been saved.
I've tried applying an alternate pattern to the part, to clear out the old pattern, then applying the new pattern, but the old, unrevised version of the pattern keeps showing up. The only way I'm able to implement the changes, is to create a new name for the pattern, then apply it.
Anyone else come across this?
Re: Hardware Hole Issue
Nat,
Scott and i talked about this a while back and he was able to reproduce it so I hope it is fixed in the next release. Until then you just have to use a new name.
Nat Wheatley
Thanks Kerry.
Scott G Vaal
Post by Scott G Vaal »
Yes, Kerry brought this to my attention and it is/will be resolved. Thanks Kerry and Nat.
