Problem with size of back panel
David Bean
Company Name: KGK Construction
Post by David Bean »
I just recently purchased a cnc and have been using ecabs for quite some time. I sized down a very basic frameless upper (basically a box) and tried to cut it on the cnc with blind dados. Everything cut fine except the back was about 3/4 too wide. I tried a second cabinet and the same thing. I'm not sure if it is the shopbot link or ecabs. The back dimensions are correct in the part list in the shopbot link but it gets cut wrong.
Any thoughts would be greatly appreciated.
Re: Problem with size of back panel
Welcome David. Can you post the job file (esj) and someone can have a look.
David Bean
I went with a full dado on this one and the back is still 3/4"+ too wide.
cnc test upper 2.esj
(208.02 KiB) Downloaded 1344 times
Michael RA Greschuk
Post by Michael RA Greschuk »
Hello David
I just cut your test cab on my machine and it cut fine. The back is 19mm too large because it has to fit into the dadoes on the sides of the cab. I believe you have a depth of 9.5mm which would make it appear 19mm too big. Hope this helps
Mike :D
David Bean
It is definately too wide. Whats strange is that its 7/8 which doesn't really corelate to anything(dado depth or side side thickness). In the shopbot link it is listed as the correct size, 9 1/4 x 10 1/2, but it cuts 10 1/8 x 10 1/2.
Thanks for the speedy reply!
Michael RA Greschuk
Hi David,
When I cut your cabinet the finished back size 9.25 x 10.5. and like I said it went together well :? You might want to post something on the other forum. Maybe someone there knows whats up
Mike
David Bean
Thanks Michael. It seems like it is a problem in the shopbot link. I have cut 4 test cabinets and they all have the same results. All the other parts are dead on.
Scott G Vaal
Post by Scott G Vaal »
David,
In the ShopBot link, load the job {*.twd} in question, perform a nest, then do an export (found on the main screen of the SB-Link). Send the {*.cab} file that it creates to cabinets@thermwood.com along with a brief explanation of you problem. Someone will take a look at it and see if we can reproduce your issue.
David Bean
Thanks Scott, I just sent it over.
Scott G Vaal
David,
I loaded your export into my ShopBot link (which makes mine identical to yours) and cannot find any problems with it. I did the math on the G-code produced by the link and it is accurate to what it should be for all parts. I reversed posted the G-Code into our Cad-Cam program here and all values measure out correctly. Daniel here at Thermwood has also been looking at it and cannot find anything incorrect. I'm not sure what to tell you to try, and I am not trying to push the blame to the machine, but at this point it seems like we should look there first before anything else. Maybe try to cut the parts at a different location on the machine to see if it matters. Or better yet, filter out the back so that a different part will get cut in that corner of the sheet (or that area of the machine) and see if the same issue happens to a diff part. Let us know your results.
David Bean
seems that one of the values had been changed causing the y axis to move disproportionately to the x axis. We changed the value and everything cuts great. Hopefully it stays that way. Thanks to all that responded especially the Thermwood people. Can't wait till I can get one of those shiny Cabinetshop 45's!
