I have drawn a shape in AutoCad that include ellipse's. Once I import them into the part editor the ellipse shapes do not come up. I have had this problem before and can't remember the reason for this. I know that an ellipse is a complicated shape. Does anyone know of a method to get an ellipse to successfuly open in part editor?
Dale
Importing a DXF into eCabs containing an ellipse?
- Dale Wills
- Company Name: none
- Country: AUSTRALIA
Re: Importing a DXF into eCabs containing an ellipse?
Hi Dale, not sure why you are having probs, after your last post about using the pellipse command in autocad i had no probs importing the ellipse into part manager and then cutting it. Is the piece of board that you are trying to put the ellipse onto big enough?
www.eastcoastultimate.com.au
I posted sometime ago about the PELLIPSE variable in AutoCAD. Set it to either 0 or 1. I don't recall getting a reply posting from the poster as to whether it worked or not, but it appears that per Jason's email that it does.
Dennis Englert
Dennis Englert
Dale,
I remember making you one in another program quite a while back that worked. I know you are trying to find a fix for it, but if you need another one, let me know.
Kenneth
Kenneth
