Jay Rockman
Posts: 9 Joined: Wed, Jan 19 2011, 6:58AM
Company Name: Professional Touch Woodworking
Post
by Jay Rockman » Wed, Mar 16 2011, 2:09PM
Hi all. I just finished the basics of a custom layout and saved the file. Not 5 min. later when I tried to open the file I get "An error occurred while loading HOOPS information from the saved file" followed by "There was an error after opening the JOB file". I've looked around on the forum and it seems like there is no solution and you just have to start over?! Great, 2hrs. down the toilet. What's going on? The program not saving properly causing an unreadable file? Other previous layouts load fine. I've tried updating drivers, I'm running V6B6, I've unchecked and rechecked the "Use hoops display list" from the settings/preferences menu...
Posts: 1896 Joined: Wed, May 18 2005, 7:54PM
Post
by Rick Palechuk » Wed, Mar 16 2011, 2:15PM
Can you post the job file.
Jay Rockman
Post
by Jay Rockman » Fri, Mar 18 2011, 2:38PM
We have tried to open the file on 2 of our home computers with no luck
Coleman, Michelle.esj
(6.66 MiB) Downloaded 587 times
JohnLashuay
Posts: 645 Joined: Mon, Nov 20 2006, 3:39PM
Post
by JohnLashuay » Fri, Mar 18 2011, 4:40PM
Hi Jay!
I downloaded the file and in place of the comma in the file name it added a "%2." I am wondering if having a comma in the file name is an issue.
The Thermwood guys will probably have an answer to this!
-John
Post
by Rick Palechuk » Fri, Mar 18 2011, 4:49PM
Try renaming the file hold the commas.
Post
by Rick Palechuk » Fri, Mar 18 2011, 4:54PM
That didn't work.
Jay Rockman
Post
by Jay Rockman » Mon, Mar 21 2011, 2:56PM
I named the new file (started from scratch) "Coleman, Michelle 2" and have had no problems with it so far...
