Score Sheet
Jason Stephenson
Company Name: Marks Joinery
Score Sheet
Post by Jason Stephenson »
Just A quick question we were going to update our bottom score sheet and were just wondering whether the mdf has to be a certain density or is it just normal mdf
jason galbraith
Country: AUSTRALIA
Re: Score Sheet
Post by jason galbraith »
I believe it has to be an LDF - Low Density Fibreboard and is not cheap. Can anyone confirm or deny?
www.eastcoastultimate.com.au
Re: Score Sheet
Jason, Jason,
In another thread about this still another Jason, Susnjara stated that the table boards that come with the machines are 32 lb density and the waste boards are 48 lb density.
Company Name: Halls Edge Inc
Re: Score Sheet
Post by Josh Rayburn »
"Ultralight" or low density fiberboard for a spoilboard does not perform well with our vacuum and tends to hold more stress after it's machined (even on both sides) and so consequently is not a good choice. It also does not hold up well as a wasteboard. Premium (double refined) MDF as a spoilboard is the best choice, and regular or premium MDF for wasteboards has worked well.
Jeremy Schiffer
Re: Score Sheet
Post by Jeremy Schiffer »
Josh, would that be what some companies call a "door core" MDF, such as Ranger board? (referring to the spoil board, not the waste board)
CS-41 4x8
CS-45 5x12
Re: Score Sheet
Yes, Rangerboard is a great choice for a spoilboard. That is what I currently have and it also holds up better to wear which translates into less often machining of the spoilboard.
