Hello Everybody.
Has anyone figured out a way to make KD/RTAs work with the 32mm system. Say, start from the front edge of the cabinet only and place holes in 32mm increments only. I want to make dowel construction and need to figure out a way to cheat the offsets and the max distance. It splits the difference between the front and back hole and drills a hole in the middle. It would have been much better if it was an increment instead of max distance.
Thanks for the help
KD/RTAs
- Georgi Baltov
KD/RTAs
Top Notch Cabinets
- Georgi Baltov
Re: KD/RTAs
I got it. Thanks to everyone that thought on it though
Top Notch Cabinets
