Moderators: Mike Iubelt , Jason Susnjara , Larry Epplin , Clint Buechlein , Mike Iubelt , Jason Susnjara , Larry Epplin , Clint Buechlein
Posts: 1263 Joined: Wed, Jul 01 2009, 2:19PM
Company Name: Halls Edge Inc
Post
by Josh Rayburn » Fri, Jul 15 2011, 8:42AM
Please see attached job file.
Take batch item 1 to CE and nest from CE.
Look at both dado operations on the left end and the right end - one of each is at .77 wide and the other is at .95 wide. I cannot explain how I even got code out of this file, but clearly something is wrong because the parts are not correct (I already ruined a couple sheets). There may be a number of errors here, software, CN....?? but I cannot figure it out.
When did the full dado operation wider than the largest tool in tooling setup automatically form a pocket cleanup operation, and why does this not happen for blind dadoes??
Export to follow shortly.
Dowling Bunk Room.zip
(1.27 MiB) Downloaded 455 times
Post
by Ryan Hochgesang » Tue, Jul 19 2011, 12:11PM
Josh,
Do you have the EXPORT and .CNC file supporting this issue? I would like to see in order to resolve this issue.
Post
by Josh Rayburn » Tue, Jul 19 2011, 12:24PM
Here it is. job file, twd file, export.
Please see sheets 9 and 10 when you write code with the attached export.
crane dado size 071911.zip
(1.77 MiB) Downloaded 458 times
Post
by Ryan Hochgesang » Tue, Jul 19 2011, 2:44PM
Josh,
I do see the oversize dado on each side panel as you mention and will keep the files under review to determine if this is a bug.
Post
by Josh Rayburn » Tue, Jul 19 2011, 2:51PM
What can I do to cut my customer two usable parts in the meantime, do you have any suggestions?
Post
by Ryan Hochgesang » Tue, Jul 19 2011, 3:09PM
I would try the same design using shelves vs. TOP and DECK ..... just a thought.
