Displayed depth different than actual depth.
Jeff Miller
Company Name: Miller Woodworks
Post by Jeff Miller »
I'm designing a wall of cabinets like a built in bookshelf with doors. There is a bump out in the wall that in essence makes some cabinets 6" shallower then the others to have the frames flush. I've drawn them as 24" deep and 18" deep but shows the 18" deep sticking out further then the others. I've checked them and they all say the correct depth but I took it to the line drawing editor and dimensioned it and it shows 20" and 17". I can't figure out where this is coming from and I restarted the program and Windows.
Any idea's?
Re: Displayed depth different than actual depth.
Hi Jeff, can you post the job file so someone can take a look at your issue.
Hi Jeff
I had a similar problem to this about ten posts ago. I was working in the cabinet editor with an assembly. Some of the cabinets were the wrong widths but displayed as the correct size. It showed up when I selected them for a cultist.
I don’t know what caused it but out of curiosity do you control + c and control + v to duplicate your cabinets or do you pull them from the side panel? I had a vague feeling it could have been copying them that caused the issue. Also I had an incidence of black and white zebra stripes with the same units.
