building a podium with an angled top?
Michael Kowalczyk
Post by Michael Kowalczyk »
Is there a way to build a 16"D X 20"W X 45"H podium with a 24"wide x 20" deep top that has about a 15 degree angle on it that can be completely CNC machined using blind dados?
Michael Kowalczyk, GM
Re: building a podium with an angled top?
Lecturn.esa
(1.67 MiB) Downloaded 732 times
Hi Michael
Here is a basic lecturn design I was playing around with.
I havent a machine so it has not been tested.
The top would have to be fixed from underneath
The angle is about 10deg
Dennis G. Blackburn
Post by Dennis G. Blackburn »
Yes - it's possible. Thermwood built this one for me "on the fly" at the 2010 IWF Woodshow in Atlanta.
Michael Kowalczyk
Hey Marc,
Thanks for the example. What I need is the have it totally set up to be assembled with blind dado joints or a combo with a rafix type lock joint. This way it could be sent to a location and assembled on the spot.
Sorry, I didn,t show the blind dados.
Just need some sash cramps and glue and your good to go.
Perhaps replace the back rail with a bracket or you can turn on or off, and adjust the dados to your liking in construction settings
Lecturn 2.jpg (10.37 KiB) Viewed 13352 times
Michael,
I don't think you will be able to addd the blind dado or kd/rta joinery to the top is it is angled. you can't add joinery to any angled parts unless you do it manually in the part editor.
Michael Kowalczyk
Hey Kerry,
Did you get any of that snow up there?
That's what I was thinking also but hoping that there was a way around it or maybe something I may have missed.
Maybe Scott or Larry can shed some light on this. I know this is not the first time some one has wanted to have a construction method, other than a BUTT joint, used on an angle joint.
Michael,
I hae been in Colorado all this week and yes we did get snow. I don't hink it was as bad in Dalhart as they had expected.
about 6 or 8 months ago I had to do a "widget" for Keith that required joinery on an angled part exactly like what you are needing for the podium. I was able to do it using a stretcher but there were some wierd little ticks in the nest that the machine was trying to cut using an eighth inch tool. When I reported this to Scott he thanked me for finding a bug. He said that the software should not have allowed me to create the joinery. Untill the next release when this bug is fixed I guess it would still work. I will give it a try tomorrow and see if I can do it again.
