Double Door/ Single Opening - No Hinge on Top
JohnLashuay
Post by JohnLashuay »
1. Open a std frameless (tall, base or upper) in the CE
2. Take it to the D/DE
3. add a hole pattern for the hinge
4. add 2 door pairs to a single opening
5. go back to CE
6. the top door is missing the hinge holes
-John
http://www.rylexonline.com
Thermwood CS 43
Scott G Vaal
Re: Double Door/ Single Opening - No Hinge on Top
Post by Scott G Vaal »
John,
Sorry, but I am not able to reproduce this. Just so I am not missing a step, here are mine:
1.) Load the std base frameless
2.) Go to door/drawer editor
3.) Set a hinge pattern
4.) Select opening and add double doors, on the add double door dialog I choose Qty. 2, then select OK
5.) Return to main and explode cab: All hinge pattern cuts seem to be there for me.
Am I missing something? If not, maybe I need your hinge pattern.
JohnLashuay
Hi Scott, those steps are correct. Here is a cabinet that has the hole pattern and the problem
-John
Master.hsf
(558.02 KiB) Downloaded 422 times
Thermwood CS 43
