TWD from Ecab 6.8 Error
Zach Froble
Post by Zach Froble »
After updating to build 8 any twd file I try to load gives me an error. The error is "Invalad Database; GetRows Binding errror. Probably caused by mismatched data type."
I load older twd files fine. It just seems to be the ones since build 8.
I was trying to get the machine set up for tomorrow morning, so any help would be appreciated.
Zach
Lyndan Designs
Machining and CAD Services
Brad McIntosh
Company Name: CNC Automation
Re: TWD from Ecab 6.8 Error
Post by Brad McIntosh »
The following was noted on the eCabinet Systems v6 Build 8 download page...
Control Nesting NOTE:
eCabinet Systems Version 6.0 Build 8 can only be used with Control Nesting Versions 5.59 Patch 1, 5.67, or newer.
So check you Control Nesting version. If you are using the more recent releases, make sure that you have 5.67 or better installed.
Control Nesting Updates
If you are limited to the PRE-5.60 release due to your control version/build, etc then make sure that you have 5.59 installed and then apply the 5.59 Patch 1.
Link to Download V5.59
Link to Download V5.59 Patch 1 (must have 5.59 installed)
Brad McIntosh
CNC Automation
Twitter: @bmcncautomation
Zach Froble
Brad,
Thank you for the reply that took care of it. I must have missed the note on the patch.
Zach
Lyndan Designs
