Partition not following settings
JohnLashuay
Post by JohnLashuay »
Here is a hutch cabinet that has a center partition in the lower section that looks like it has a neg inset for the top, but it is set at 0. Can someone look at this? I can't make heads or tails of it!!
Thanks!!
-John
Hutch_1992_24-24_5-6-6-8-8.hsf
(2.46 MiB) Downloaded 1173 times
http://www.rylexonline.com
Thermwood CS 43
Scott G Vaal
Re: Partition not following settings
Post by Scott G Vaal »
John,
Not sure here. The version history goes straight from V6Bld6 date saved 6-15-2011 to the release version of V6Bld8 dated 4-2-2012. Do you still have this cabinet as a V6Bld6 cabinet or did you save over your only copy? If not, please get me the V6Bld6 version of the cab. What if any changes did you make to this cabinet in Bld8? Was the cab like that when you loaded it as the V6Bld6? I removed it and then re-added all the parts and cannot seem to get it to reproduce. So not sure if it was an old bug or not. Having the older cab may help me answer that.
JohnLashuay
Hi Scott, I'll look to see if I have something from before.
I already had that partition in place then I noticed there were no KD fittings at the top. As soon as I added the KD's to the top of it the neg inset showed. This all took place shortly after I added neg insets to the left and right ends.
Not sure if this will help. I'll try to track down previous cabinets.
Thanks for checking this out!
-John
Thermwood CS 43
JohnLashuay
Scott, I emailed you some possible cabinets used for this one.
Any questions, let me know!
-John
Thermwood CS 43
Scott G Vaal
John,
With the clues you gave me, I finally figured it out. Amazingly it is a long existing issue with resizing the height of a cabinet and then going into the shelf/partition editor, highlighting an existing partition that is attached to a fixed shelf, then going to con-setting and selecting OK. I have this listed and it will be fixed for the next release. Thanks for reporting it. For now, if you have this specific scenario, you would want to change the construction of the partition by right-clicking on it in the main and selecting the construction tiered menu and choose the edge and construction type desired.
JohnLashuay
Thanks Scott! Good to hear.
-John
Thermwood CS 43
