Flip side issue
Georgi Baltov
Flip side issue
Post by Georgi Baltov »
I think that v5.70 addresses that issue but not quite I believe. I'm attaching some files with export and pictures. We don't do full sheet flips and it's still doing some of the flip operations as face operations. It's happening with our 306 tool. Anyways check it may be the issue was solved in v5.70. Let me know if you need more information
Flip Op on Face Error.zip
(2.01 MiB) Downloaded 439 times
Daniel Odom
Re: Flip side issue
Post by Daniel Odom »
I've encountered the same problem with single part flip ops. When the flip operation part was nested by itself, say a sheet of the same flip op part, it worked fine; but when nested with other parts a dado was produced on the wrong side. I can't post any files at the moment, but I'm using the latest updates. My work-around was to nest the flip parts separately.
Georgi Baltov
Re: Flip side issue
Daniel,
does this occur in V5.70 as well?
Daniel Odom
Re: Flip side issue
Yes, I've tried the update but still have the same problem.
Georgi Baltov
Re: Flip side issue
My problem occurs on the same tool that is easy to isolate so my operator decided to skip it whenever the machine picks it up and move on to the next tool.
