Too Many Shelf Holes
Nat Wheatley
Post by Nat Wheatley »
A number of the shelf holes are duplicated on this cabinet. Some of the drawer slide holes do fall on the shelf holes, which may or may not be contributing to the problem.
1.hsf
(1.81 MiB) Downloaded 571 times
Brad McIntosh
Company Name: CNC Automation
Re: Too Many Shelf Holes
Post by Brad McIntosh »
Nat,
Since you have basically a FULL LINEBORE on each gable, how were the shelf holes applied in the first place.
Brad McIntosh
CNC Automation
Twitter: @bmcncautomation
Nat Wheatley
The holes were added with the top (purple) adjustable shelf.
When it was cutting the file for the front row of holes, it appeared to drill every other hole, then go back over that same area and drill a full row of holes.
Brad McIntosh
Nat... again - how were the adjustable shelf holes applied/created? Did each shelf add a certain number of holes and you adjusted spacing between shelves? Or did you use just one shelf to apply all the holes and the others were added without related holes?
Or did you use some other method?
Brad McIntosh
CNC Automation
Nat Wheatley
See first line from my last post.
Rick Deskins
Company Name: Thermwood
Post by Rick Deskins »
I think I have found the problem in the line boring code. I will have to verify it with scott and get it on the list to be fix. It seems that it is finding the 32mm line bore then going back and finding a 64mm line bore with the same holes, hence the extra drilling of every other hole.
Rick Deskins
Brad McIntosh
Nat,
Sorry about that... long week.
Brad McIntosh
CNC Automation
Nat Wheatley
Brad,
No problem, same here!
Nat
