Unsaved cabinets even after I've just saved it...
BenRatt
Post by BenRatt »
I've had a glitch for a while now, whenever I close a cabinet in cabinet editor I always get the message "Are you sure you want to start over? There are unsaved cabinets in the current assembly". It does this when I haven't made any changes. I can open a cabinet and then close it without doing anything to it and I get this message. Also, I'm not working on an assembly, it's just a cabinet. It does it even after I've just saved the cabinet and I'm trying to close it out. Anyone else have this issue? It was doing this before build 8.
Ben Ratterree
Blue Ridge Cabinetworks
Spartanburg, SC
http://www.blueridgecabs.com
Company Name: Halls Edge Inc
Re: Unsaved cabinets even after I've just saved it...
Post by Josh Rayburn »
Yes Ben it always does that. Frustrating.
Post by Donald Thomson »
You will also get this same annoying dialog when you exit from working on a batch. Save the batch, then try to exit eCabs. It will ask you if you want to save the job, again. :?
