I had another post here, but it has vanished.
I was trying to find out the difference between esa & esj files.
I have an esa file I downloaded from Ecabs that Ecabinets software will not open and the Thermwood machine shows gibberish in the G-code area.
here is a rough example as I can remember it:
\\\\\blockedfiles//////
^&&__*^%@&*&%%!@#$^?}}{|||
the joys of having to use 2 or more computers to get work done.
thoughts?
suggestions?
esa files
peter w palmer
- Company Name: TSC
Rick Deskins
- Company Name: Thermwood
Re: esa files
ESJ is a job file, ie a saved batch or room, or both and may contain drawings. ESA is an assembly file made up of cabinet(s) and/or object(s). Both files can only be opened by eCabinets. ESA files can only be loaded in the Cabinet Editor, Batch , or the Room using the Assemblies tab. You can open the ESJ by using File-Open or the Open Button in the toolbar. To send it to the machine you have to write CNC to produce a TWD file that can be loaded in Control Nesting.
Rick Deskins
