Nesting to the center of the sheet?
Ayberk EKSIOGLU
- Company Name: Sarp Ins.Mob.San.Ve Tic.AS
- Country: TURKEY
I have the attached Panel List.xls. I need to fit 6 pieces: 2 by width (no problem here) and 3 by length. I use a 8mm knife. In order to fit 3 pieces by width I deselect Nest to the Edge of the Sheet. I can use a 8mm collar at max. However, both of the long sides (upper and lower 280cm sides) of MDF are damaged, about 2cm each, so I don't want to nest it to lower right, lower left, upper right or upper left. I want to nest it to center, matter of speaking. What to do?
- Attachments
- Panel List.xls
- (16.5 KiB) Downloaded 979 times
Daniel Odom
Re: Nesting to the center of the sheet?
Maybe you can choose the best corner to nest to then use a g92 to move away by however much you need to move.
Matt Snowball
Use the 'enter void' facility in CN to produce two voids along each long edge, covering the damaged area . These will not be nested on.
Ayberk EKSIOGLU
- Country: TURKEY
Thanks a lot! Now, I'm working on to find out how to do that. I couldn't learn much from Control Nesting Manual.
So on Sheet Entry I would tick Rectangular box and type (x)2800 and (y)2100 and on Void Entry I would type (x)1 and (y)1050. That didn't work.
When I type in my MDF size (280x210cm) it draws on the opposite corner (upper left) instead of where my pin-ups are located (lower right). Isn't that counterintuitive?
