I believe that if you change your fixture offset of G901 to G52L1 for the popup pins associated with the corner of your sheet, it will work. I do not get an out-of-bounds error on any axes, but I'm using the desktop version of the control.
I thought i already had it set to use G52L1, i am still learning g code but i though that this section of code referenced
the fixture offset G52L1 and set material dimensions.
What are the X and Y coordinates recorded in entry # 1 in the Fixture Offset Table on the machine? Do they correspond to the coordinates of the corner of your table closest to the pop-up pins?
Your program has MAX X position of for T1 (Outline tool) of 2414.7649 mm
If your G51L1 has a X component of 3670.5 mm
And your X Axis Adjust (Shift) is -2420
Assuming you are using a 1/2" tool (~12.7 mm dia) then the cutter compensation would shift this MAX X to an actual position of 2,421.1149 mm (2414.7649+6.35) as it went around the parts at the end of the sheet.
This would put the center of the tool 1.1149 mm (2,421.1149-2420) past the pop-up pins at an MACHINE absolute X axis position of 3,671.6149 mm.
You need to check what your absolute limit is for your X axis. (Check the OUT LIMITS.)
