5.72 control nesting update
Thomas strembitsky
i recently purchases a cs43 which is running the THM 8.1.3 version of the supercontroller. After installing the new control nesting software version 5.72, there are a few things in the update that are only supported by the THM 8.3 version. Does anyone know what the 8.3 version has that the 8.1.3 does not
http://www.trueform.ca
CS43 cnc
CS43 cnc
- Scott Marshburn
Re: 5.72 control nesting update
"I also have a question about the 5.72 upgrade I see that there are some fixes that require eCabinets 6.0 build 9 •Grouping failing. This fix requires having eCabinetSystems 6.0 Build 9 or newer. (FIXED)
•Inset carvings rotated improperly. This fix requires having eCabinetSystems 6.0 Build 9 or newer. (FIXED) should we wait for the eCabinet upgrade before installing 5.72 ? "
We are beta testing build 9 now. Maybe they posted the CN update on the open forum accidentally. Forrest
- Scott G Vaal
Thomas,Thomas strembitsky wrote:i recently purchases a cs43 which is running the THM 8.1.3 version of the supercontroller. After installing the new control nesting software version 5.72, there are a few things in the update that are only supported by the THM 8.3 version. Does anyone know what the 8.3 version has that the 8.1.3 does not
The only difference will be the Label Recovery feature will not be available.
In THM 8.3.0 and newer an option for printing labels per part or sheet is available in the Control Options menu. This option is called Label Recovery. (ADDED)
Ability to designate CNC output as a CNC Database for Label Recovery use. (ADDED)
- Scott G Vaal
Scott,Scott Marshburn wrote:"I also have a question about the 5.72 upgrade I see that there are some fixes that require eCabinets 6.0 build 9 •Grouping failing. This fix requires having eCabinetSystems 6.0 Build 9 or newer. (FIXED)
You can upgrade to the latest CN now if you want. There are obviously some isolated grouping and carving issues that will not be completely resolved until the new eCabSys is released to everyone. But, if you do not have any issues with grouped slab doors and or drawer fronts now, you should still be OK with the new CN and the current eCabinet Systems.
- Scott G Vaal
Forrest,Forrest Chapman wrote:We are beta testing build 9 now. Maybe they posted the CN update on the open forum accidentally. Forrest
It was not by accident. the latest CN will support the current and the beta version of eCabSys. Sorry for any confusion.
