Bad Part Outline
Company Name: Halls Edge Inc
Bad Part Outline
Post by Josh Rayburn »
I don't know how / why it happened, but the back of the large cabinet (charlie 02) has a bad outline.
The job file is attached. No export, because the problem is visible at the job level before it gets to that point. However I didn't notice until my operator came and got me and showed me the bad part that got cut out :wall:
Please let me know if you can find the trigger so I can avoid pulling it in the future...
Thanks!
mica charlie 110512.zip
(897.55 KiB) Downloaded 342 times
Re: Bad Part Outline
OK after some poking around I've found that if I put a part editor 'cut all the way through' pocket on the upper right corner of the part, then the outline appears correct. We'll find out in a minute when the bit is done spinning.
Alright, well it all looked good on the screen with that little corner being cut away but the router didn't cut it right the second time either.
I love the three sheet jobs where I have to recut two sheets. :wall: :wall:
