Closet suspension rails
ScotAcree
Company Name: Scot Acree Woodworkig LLC
Post by ScotAcree »
Would like to know what an appropriate size to make the notch in a Partition for the suspension rail to fit into.The Camar rail looks to be 1" in height.Not sure on the depth of it.I have a couple threads that I read on the forum on the topic (http://www.thermwood.com/forums/viewtop ... ion#p64990),and the notch height looks to be 4".Not sure why,when the suspension rail is an inch in height.Probably for the adjustment for the knock in dowel brackets I am guessing.
Scot
Wayne Adelkopf
Company Name: Noble Woodworks Inc.
Re: Closet suspension rails
Post by Wayne Adelkopf »
The notch is 4" so that you can install the cabinet on the rail without a fight.
Nat Wheatley
Post by Nat Wheatley »
Sent this info in a PM, but thought that I'd post here as well:
Here are the item numbers for the Hafele hanging rail and brackets that I use. Both the rail and brackets come also have plastic covers (separate product numbers):
290.11.901 Hanging Rail
290.02.711 Left Bracket
290.02.710 Right Bracket
The brackets attach with 2 - 5mm screws. The extra height in the rail notch is for up/down adjustment.
Attached is a file of a shelving section that shows the height of the notch I use.
Nat
72 Seed.hsf
(1.29 MiB) Downloaded 1045 times
