Dust left from cutting
- Thom Davies
- Company Name: Dawn Group
- Country: NEW ZEALAND
Hey how's it all going?
Just wondering what other users of thermwoods do with the dust left on the cut sheet after you take the parts off. Do you blow the dust off the cut sheet (which goes every where) or do you suck it up with a vacuum? Or do something else with it?
Thanks inadvance
Thom Davies
Thanks inadvance
Thom Davies
- Thom Davies
Yeah i inhale some as well so does every body on the floor!!!
But the biggest problem is dust getting on the tool collets and then i get alot of that brown collet burn and also get on the parts i have just cut and some times labels dont like being stuck to dust when i try to put them on the parts!
Thom Davies
Thom Davies
- DanEpps
- Company Name: Dan Epps
Oh the labels love to stick to dust...you just can't get the dust to re-stick to the part after you put a label on it
Not having seen one of the routers I'm not much help. Is there not a dust collection attachment point near the cutter? From the machines I have seen though, it seems like it would be a pretty simple matter to connect a flexible hose to the cutting head.
Dan
Dan
Nick M Singer
What little dust is left over after machining (good primary extraction is the key) is vacuumed up and then finally blowen away with an air duster. with the strength of my extraction system I have almost zero dust on the cut parts so sticking lables is not a problem, the only problem I do have occasionally is that it is so strong that small parts can get lifted off the table during machining, but that is more a factor of a slightly under spec vac pump.
David Hall
We don't use labels anymore so no problem with them sticking. We just write the cab number on the part and our assemblers know where they belong. If this is not an alternative for you we also had a vavumn line that Y'd
off the main line over the center of the table and had a flexible hose with wand attached. Now that we write on the parts we slide the cut parts off the table reload new sheet and mark parts while the machine is running then stack parts on cart and lift sheet up to dump dust on the floor to be swept up at end of day. This keeps our dust collector from filling up to fast.
- Brian Shannon
I don't have a problem with dust on my parts but do have some on my table after removing the cut parts. I brush the table off with a hand brush then sweep the floor later. My dust collector is a 3 HP Oneida and I am thinking of upgrading to a 5HP. Now I worry about the small parts moving from too much vacuum. I have some troubles with the vacuum brush cup pushing small parts. The stronger vac may make this worse.
Brian
Brian
- Thom Davies
Hey guys
One of the reasons we have dust left on the cut sheet is cos the skirt around the cutter is set up to the smallest cutter we use so when it uses the 4mm cutter the skirt is just touching the board. when it cuts out the parts the skirt is sitting up from the board 13mm. we could make a longer skirt but when it uses the small cutter it might scratch the board because the skirt would be set up for the longest cutter. The extraction on the thermwood is very good as well.
Thom Davies
Thom Davies
- Dale Wills
- Company Name: none
- Country: AUSTRALIA
We temporarily have our dust extraction setup through our old extractor. It's not doing too well as its leaves alot behind. We are waiting for a new design from the states which apparantly is the 'bees knees'. It's not constructed for our power set-up here in Australia yet. So at the moment we are just blowing the dust off with an air nozel which sends it everywhere. I've got this kick ass dust mask which looks like something Darth Vader would wear. It looks cumbersome but is a good design and works well. Shortly we will have some help via an industrial vacuum which we are looking at. Plan to suck off all the dust before we place labels on.
Dale
Dale
- Thom Davies
- Paul Ford
We bought a 4 bag dust extractor second hand over a year ago. It has been brilliant! All we do is give the part a little wipe with the back of the hand and stick the sticker on. Once we have emptied the sheet off and clashed everything it is as easy as lifting one side of the sheet and giving it a flick which just puts all the dust on the floor. doesnt seem to leave much dust on the floor at all and certainly no dust in the air to breath in.
We are looking at connecting our big outside extractor up over the christmas break so i will tell you how that goes in the new year.
- Thom Davies
- Paul Ford
Hey Thom,
Most of the time the hood is almost touching the top of the board. If we are cutting 30mm we use the 12mm cutter and it is almost touching then aswell.
Take a look at this (It might be in the same place on your comuter)
I have thought about getting one of these as it would also brush the surface of the board hopefully leaving no dust at all.
C:\\Program Files\\Thermwood\\eCabinet Systems\\store\\Vacuum Brush Cups\\Thermwood
