Hi,
Could someone please tell me what is the current best method of adding tandembox drawers to get the drilling pattern on the drawer fronts & carcase sides. Or point me to a thread that discusses the topic. I have tried the search function but most of what I find is old information & I don't know how much of it relates to the current build.
Gerry
Current tandembox best practice
- Gerry A Brown
- Company Name: Old Style Woodwork
- Scott Marshburn
Re: Current tandembox best practice
Hi George I personally have used this type of drawer but I did come across this type of whole pattern in the hardware hole editor help file go to hardware hole editor and click on the(? ) and look under integrated drawer systems.
- Gerry A Brown
Hi Scott,
Thanks that was very helpful.
We use a plant on gable on end cabinets & so need a full clearance on that side & a half clearance everywhere else. We are considering drilling in between those two dimensions on the drawer front. This works out to a .6 mm difference between the two. We should be able to use the adjusters to deal with the difference.
Is this common practice? It seems it would be too much complication to have one pattern for a gable that has a plant on & another for a gable that butts to the next cabinet?
Gerry
Gerry
jason galbraith
- Country: AUSTRALIA
You can still set the same drilling pattern but you would change the reveal amount when applying the draws, or I'm missing something in translation.
www.eastcoastultimate.com.au
- Gerry A Brown
Hi Jason,
No you are not missing anything I am or was
I was not getting the complete picture of how this works.
As you say the software compensates for drawer location on the box when it is applied.
Gerry
Gerry
