Z AXIS
- Company Name: Moduform
- Country: SOUTH AFRICA
Z AXIS
I Have re laoded the v7 software after my power supply bomded out, now after I have relaoded the software again and checked the tool lenth censor and set up the waste board,I have a problem. As soon as I want to run the flycut the machine only drops with 10mm and then runs the program. There seems to be a setting I am missing with relation to the daylight and the actual waste board. Please help. Theo
Re: Z AXIS
Hello, if you can give us a call at 1800-533-6901 and ask for programming, we can figure out what may be causing issue. This forum is not regularly monitored by Thermwood personnel so the fastest way to solve your problem is to contact us directly.
Joe Harger
Software Support
Joe Harger
Software Support
