Having trouble moving a cabinet into place
Post by Donald Thomson »
I've attached a simple kitchen job. There is a cabinet hanging out in the room that I want to move under the long cabinet on the long wall. It is an open plate storage cabinet.
When I try to move it, it goes to a certain spot, stops and jumps to another location. I continue trying to move and it repeats this operation of move, stop jump back to start. I've tried associating it to the long wall and not associating it to the long wall. I get the same results. :wall:
Can anyone tell me what I'm doing wrong because I am at a loss as to how to move it into place.
Thanks!!!
Bob Cabaniss kitchen.zip
(2.68 MiB) Downloaded 542 times
Scott Marshburn
Re: Having trouble moving a cabinet into place
Post by Scott Marshburn »
Donald,
Try changing the mounting height before bringing the cabinet into custom lay out. However I was able to move the cabinet by associating it to both walls and adjusting as needed in the elevation view.
Wally Schneeberger
Post by Wally Schneeberger »
Also make sure that your Place Cabinet is set to FREE STYLE.
Dennis Englert
Post by Dennis Englert »
I removed the cabinet. Changed to Elevation view. Then I re-inserted it, but chose the down arrow icon. Change the mounting height to 70.4031, which is the bottom of your other cabinet. It then placed without any issues, i.e., jumping around, etc.
There is a video in Knowledge Base>Custom Layout about stacked cabinets. It is actually a little more complicated than what you are trying to do, but does specify that you need to change your mounting height. The software can not place cabinets on top of each other, which is what it was trying to do. The video also explains a method of adjusting the height of multiple cabinets of different sizes that are stacked.
If the Placement Mode was set to Free Style, you could've placed it anywhere, including merging it into the wall or another cabinet.
Dennis
Thank you all for your replies.
It is weird that I can't place these two cabinets one on top of the other. In the previous kitchen design I did, I had an upper corner cabinet placed. I then created an appliance garage using another corner cabinet and I got the two to line up perfectly without any of the jumping around that is happening with this kitchen. Of course, the previous one was done in the previous version of the software, so I don't know if there was a change.
Thanks again everyone!
Dennis Englert
Don,
I'm not sure how you got the last scenario to work, but to the best of my knowledge this has been the behavior of the software since Day 1. You can not locate two upper cabinets that have the same upper mounting position in the same spot. You can always move a cabinet after it has been placed, but if "Align to Back" is active, then it has to snap to the right or left of an installed cabinet or a wall. Aside from the method previously stated, a bank of upper cabinets can be made into an assembly and then installed as a unit. There is a video on that, also.
Dennis
Thanks Dennis.
I deleted the cabinet I was having problems with and then brought it back using Free positioning and everything is cool.
I appreciate the help with this.
Have a great 4th of July!!!! :beer:
