85% of my time waiting between mouse clicks
Post by Donald Thomson »
It seems that this new release is really slow. I actually had my wife time me during a 1 hour session of using eCabs. It turns out that I spend about 85% of my time waiting for things to happen after I click on an action. Whether it is adding a drawer or door, changing the position of a stretcher, moving between editors, going from an editor back to the room editor, etc, etc.
So in a 1 hour period of time I spend about 51 minutes waiting for things to happen and about 9 minutes actually clicking to cause an action to happen. This seems like a inordanent amount of time waiting for a piece of software to respond. Plus it is a lot of thumb twirling which isn't saving any time in designing cabinets.
I am running a pretty high end computer Dell XPS, quad core processor with 16GB ram and Windows 7 Pro 64-bit, that all my other software runs lightning fast on including another cabinet design package I am testing.
Is there any way to speed eCabs up? Maybe to a 50/50 mix of actually doing something and waiting for the software to actually do it? That would be a large time savings right there.
Terry Hall
Re: 85% of my time waiting between mouse clicks
Post by Terry Hall »
Don, I believe my computer specs are pretty similar to yours. Mine is lightening fast with this latest build. My laptop hasn't suffered any ill effects either. My desktop is probably 4-5 years old. Lately I've been experiencing several shutdowns with the blue screen of death( on my desktop). After doing some research I downloaded slim cleaner with driver update, aware of the fact that I haven't kept up with driver updates for some time, simply because I'm too busy. The software initiated multiple driver updates also many registry fixes. The software seems to have solved the bsd problem and my computer is as fast as it was when it was new. Ecabinets is lightening fast. Don't know if this could be part of your problem, but it was certainly part of mine, problem seems to be solved , at least for the time being. :D
Terry Hall
Incidentally, could be a tabs problem too.
Rick Deskins
Company Name: Thermwood
Post by Rick Deskins »
Don, what video card to you have?
Rick Deskins
ATI Radeon HD 4800 series with an analog LCD display on one output and a digital LCD display on the main output.
eCabs runs on the display on the digital output - not that that should make any difference in software performance.
Rick, just to give you an idea of latency, when I finish in the cabinet editor and am ready to return to the room editor, where I came from to edit a cabinet, it takes upwards of 30 seconds before I can actually starting doing anything in the room editor again.
Using the attached cabinet - I went in to delete and put new doors and drawers in to work around the material cutlist issue with some doors and slab drawers. When I clicked on Main to exit door/drawer editor to go back to cabinet editor it took 44 seconds. Between changing the doors and getting back to my room to go into another cabinet and fix that, there was 72 seconds of simply watching the hour glass go round and round. That does not count the time it takes to add each drawer and door. I would estimate when you add the twirling the thumbs time, I have more then 100 seconds just waiting while taking about 10 seconds to click the mouse to cause an action. This seems very excessive to me.
Island cabinet.hsf
(3.36 MiB) Downloaded 657 times
Don,
Have you downloaded and installed the latest drivers for your card?
Scott G Vaal
Post by Scott G Vaal »
Don,
Is this PC a laptop or desktop?
Rick Deskins
Donald Thomson wrote:Rick, just to give you an idea of latency, when I finish in the cabinet editor and am ready to return to the room editor, where I came from to edit a cabinet, it takes upwards of 30 seconds before I can actually starting doing anything in the room editor again.
If all your cabinets are in the room, have you ever tried the adjust features tab in the item window to change doors and drawer fronts? It would save all the back and forth to the cabinet editor.
Rick Deskins
Rick - I have not tried that before. :D
I do learn new things about this software all the time. Unfortunately, I have not had time to sit down and read the new manual from front to back to find out all the capabilities. I discover as I go along.
I selected a cabinet that has 8 drawers with dbx's in it and then went into Adj. Features and selected Drawer Boxes and it told me there were no drawer boxes in the cabinet. I'm confused. How does this feature work?
Rick Deskins
Well, there are two types of drawer boxes. Change Drawer Boxes changes drawer boxes added in the drawer box editor. Change Drawer Boxes with Fronts changes drawers boxes that are added in the door/drawer editor by checking the add drawer box option.
Rick Deskins
