Have the latest v13. While in Custom Layout and go to render the project, it immediately crashes. If I hide the pulls it doesn't crash. Any suggestions on cause and fix appreciated. Thanks.
We have discovered an issue with the Pull Detail option in the presentation view causing a crash situation if it is not set to max. Please do the following and it should take care of your situation. Go to the Render View area, then select the Presentation Settings button on the left. Set the Pull Detail slider all the way to the Max position, then select OK. Now, perform the presentation view and it should work for you. This will be resolved in the next build.
