Door Hardware hole Pattern
Ted Illi
Company Name: Vanity Fair Custom Cabinetry
Post by Ted Illi »
I've done everything the same per the training instructions etc and get the hole patterns the way I want them for everything. The drawer slides and door hinge mount show up perfectly but the door hinge hole (35mm hole) pattern does not show up? The slides, hinges, and mounts all show with the correct number up in the buy list. Whats going on? Any help appreciated..... very frustrated to say the least! :(
Ted
Dennis Englert
Re: Door Hardware hole Pattern
Post by Dennis Englert »
Ted,
Send your cabinet to cabinets@thermwood.com
Dennis
Ted Illi
Post by Ted Illi »
Dennis Englert wrote:Ted,
Dennis
Please find attached the cabinet in question. Hope this is the correct file? This same problem is happening to all cabinets. Hope you can lend some assistance. Thanking you in advance
Ted Illi
60 Vanity Ft.hsf
(2.04 MiB) Downloaded 1203 times
Brad McIntosh
Company Name: CNC Automation
Post by Brad McIntosh »
Ted,
I believe Dennis had wanted you to email the cabinet to the support group. Hopefully someone there will review this thread and see your attachment.
Brad McIntosh
CNC Automation
Twitter: @bmcncautomation
Dennis Englert
Saw the post this morning.
While the doors are designated as Build in House, these are 5 piece doors will not show the hole pattern. It does not cut these doors on the machine. If you replace the doors with a slab door, you will see a pattern.
Dennis
Ted Illi
Post by Ted Illi »
Thanks much to all. I now understand why the holes don't show up or get drilled. However the holes still need to be drilled? Also now know why in house 5 piece flat panel doors made with sheet stock don't get nested or cut either. Is a separate door program for building in house doors required? Wondering what others do to run in house doors components?
Ted
