Create a display panel in cabinet editor 3 1/2 wide x 30 or so high. Take it into part editor. Then in the contour area select create edges. Using the offset tool off set the left by 1/2" then offset this line by 1/2". Now offset the top and bottom by say 3" Trim this geometry to create a rectangle. Now using the fillet tool set the fillet to 1/4 and create a fillet fro the left and right at the top and bottom of this rectangle. Now click on exit contour. eCabinets crashes every time for me. But If after creating the geometry I click on delete duplicate entities I see a line at the top and bottom of the rectangle that were not there before. If I delete these lines the program will exit contour mode with no problems.
Click this link to see a video that shows this problem.
http://youtu.be/JpSdGA3aRpA
eCabinets crashes when exiting contour mode
- Scott Marshburn
- Scott G Vaal
Re: eCabinets crashes when exiting contour mode
Scott,
Thanks for reporting this. I am able to reproduce it and will get it resolved for the next release.
- Scott Marshburn
Thanks Scott for looking into this.
