Would anyone be able to remind me if there is a way to change the width of the angled (center) back of the 90 degree corner cab? If it can be eliminated at all?
Tim
Width of angled back on corner cab
- Scott G Vaal
Re: Width of angled back on corner cab
Tim,
This is controlled by the Corner Gap setting on the Corner Settings tab of construction settings. If you make it a larger value, the center back will get wider. If you set this to zero (0), it will remove it all together. Hope this helps.
Thanks Scott!
Also, the width of the center back is double the corner gap.
Dennis
Dennis
