Changed Computer Name, Registration Code Won't Work
Nat Wheatley
Post by Nat Wheatley »
I'm setting up a new (to me) computer to run Ecabinets. I loaded the software, entered a new code, which worked fine. Problem is I changed the computer name after this (no idea what the original name was) and it now needs a new registration code. I can't generate another code as it tells me I'm up to my limi
Any way I can get this running with the code I have (that I generated today)?
Scott Marshburn
Re: Changed Computer Name, Registration Code Won't Work
Post by Scott Marshburn »
My guess is probably not. You will most likely need to contact THM to get the new code. It would seem to me that the code that you got today would be tied to the computer’s IP address rather than the actual computer’s name. But that is way over my head.
Nat,
You might try System Restore and restore the computer to a time before you changed the name.
Rick Deskins
Company Name: Thermwood
Post by Rick Deskins »
I reset your account. Please try to generate a new code.
Rick Deskins
Nat Wheatley
Up and running again, thanks very much for the help.
Nat
