Apron front single
Wally Schneeberger
Apron front single
Post by Wally Schneeberger »
Does anyone have a HSF for a Stainless steel apron front sink - 36" ?? I like the Kraus but don't know how to make & save one.
https://www.directsinks.com/kitchen/kit ... l?___SID=U .
Wally Schneeberger
Re: Apron front single
Anyone???
Hi Wally.
Ive been playing around with stl's a little bit
Not sure if this is workable but see how it goes
kraus 36a.jpg (4.02 KiB) Viewed 12826 times
kraus 36a.hsf
(56.02 KiB) Downloaded 716 times
Wally Schneeberger
Thanks Mark -- I'll give it a try!!
Wally Schneeberger
Mark -- there is something wrong with that HSF. It screws up my plan and I have to hit UNDO before my screen goes back to normal have a look at this and the big circle behind the plan--
Hi Wally
I see what you mean.
That round circle is the drain hole :(
The sink was about 19meters wide so the whole kitchen was in the sink.
I took it back into the part editor and have resized the sink so hopefully this one might work.
kraus 36b.hsf
(54.02 KiB) Downloaded 761 times
Scott Marshburn
Post by Scott Marshburn »
You do have to be careful with models downloaded from the 3D Warehouse. Sometimes they are quite large. So be sure to scale them before exporting.
Wally Schneeberger
Mark McCallum wrote:Hi Wally
You did GOOD Mark!! LOL. It works well now -- have a look --
Hi Wally
No problem.
That's a nice decent sized kitchen.
You have put a lot of effort into the presentation. It looks great! I hope you get the job. :)
I haven't actually seen stainless sinks like those, perhaps they will be the next big thing.
I thought you might have put the stone over the top of the sink edge.
I suppose they load the gap between the sink and the stone with silicon?
Wally Schneeberger
Mark -- it depends on what type of CT the customer picks. If it is Granite or solid surface then it is under mounted but if it is laminate I make a template and slide it in and silicone between the sink and counter. There is no gap to fill as the template is exact.
