I am having trouble placing cabinets on walls where they should be and this worked just fine previous to this build . I am wondering if there is new 'feature' I am
unaware of . When I go to place cabinets on a wall with 'move in wireframe' sometimes they place correctly on a wall and sometimes they rotate themselves
at the last minute 90 degrees to the wall . Other times they work fine but again sometimes they do not mount to the wall but seem to placed into the wall
by and inch or two. I am resorted to experimenting with 'move increment for an object to get cabinets in the correct place in a run. This is very frustrating
as this is pretty basic functionality that should never change ... Thanks in advance for any help . Bill
Please post a job with concise steps that will reproduce what you are seeing and we will look into it. I have tried several things and cannot reproduce it at this time. So hopefully if you get us your scenario, we can get you an answer. If you would rather not post the job here, you can send it in to us at { cabinets@thermwood.com } and we can investigate it on Monday.
Here is the file . I tried to move in wireframe cabinet 9 onto wall 3 and it will not mount on the wall without flipping
90 degrees to the wall . I tried doing a move increment on cabinet 12 on wall 2 to get it to sit on the wall correctly and
it will not move when I do Shift down arrow . I tried that to get it to sit on surface of the the wall.
Scott,
I sent you a job back in November of last year that had this issue and it still pops up every once in a while. We have never been able to track down what causes it.
The only way we have been able to fix it is to start over.
