Suggestions for program changes
Fabian Flores
- Company Name: Finecraft Custom Woodworks
Is there a specific forum where we could suggest changes/improvements for future builds of eCabinet Systems?
- Scott Marshburn
Re: Suggestions for program changes
Hi Fabian
There is not a specific forum for this. You can post here with any suggestions and/or request. Also in eCabinets at the top of the tool bar if you click on communication and select feedback it will take you to a web page that you can make any suggestions or report problems etc.
Fabian Flores
Oh alright, thanks!
Well, I was wondering if, in the future, the line drawing area could be more connected to the layout in the main view. Meaning, if you make a change in the layout and already had line drawings made previously, instead of having to redo the whole drawing to reflect this change, maybe it could update instantly as you change the parts. Or maybe it could be possible to add dimensions to the layout itself instead of having a different interface for it.
Also when adding dimensions, would it be possible for the program to automatically detect which way you wanted to add a dimension, as in vertically or horizontally, and have it change back and forth freely? Maybe by which direction the cursor is moved.
Fabian Flores
Could materials for doors and drawers be more custom when choosing a 5-piece instead of a slab, similar to the way materials are chosen for display cubes?
I have Version 6 Build 17.
Thank you
Thank you
