I got excited when I seen the latest update with the option 'Ignore Cut Through Depth' but then realized you cant apply this to outline cuts? This doesn't help us at all.
At the moment we need to manually adjust the daylight at the machine to achieve this.
Basically we have a few drills that need to cut through by 2mm along the outline set at 0mm on certain jobs with camlock fittings to avoid double machining.
We would appreciate if this option could be added in a future update as it would be a lot of help to us.
Thanks.
