no rta holes
- Company Name: Alpne Cabinet and Woodwork
no rta holes
Recently when I choose lock dado I am no longer getting the holes for the rta fitting. Any idea what could be the cause? All was fine in the same job until the last few cabinets.
Re: no rta holes
Make sure you have the kd fitting associated to the cabinet/cabinet parts for those cabinets. You can also associate different hardware hole patterns with the same kd fittings. For example on cabinets without finished ends I made a new hole pattern and deleted the large kd hole and made the 5mm drill hole a through hole. We can assemble the cabinets and rather than clamp just screw them together.
Lyndan Designs
Machining and CAD Services
