DXF and shape manager
Bill Collier
- Company Name: Cabinets Counters and More
I created a drawing using AutoCAD 2011 LT and saved it in AutoCAD 2000 DXF format. The drawing contains nothing but lines, arcs and circles. AutoCAD indicates that 20 objects are found when the entire drawing is selected. When I import the drawing into the shape manager, I do not see anything. I do not receive any error messages. Also, shape manager indicates that 21 entities are present. I went back into AutoCAD and moved the drawing to 0,0 and re-saved. This did not change the results when I import the DXF into shape manager. Can someone tell me what I am doing wrong? Thanks!
- Scott Marshburn
Re: DXF and shape manager
Hi Bill. Would it be possible to post the dxf file? I do not have AutoCAD But I can open the dxf file in draftsight and take a look at it
- Kerry Fullington
Bill,
Try saving the .dxf as an AutoCAD R12 file and see if it will open.
If that doesn't work you might try exploding the file in AutoCAD then save it as an AutoCAD R12 .DXF.
