We've had our CS41 for some years, but are only now using profile modeler for the first time .
We can create the part , write CNC, and cut the part OK . However the program appears to only want to lay the parts out in the 'X' direction when writing CNC.
Parts that would easily fit along the long axis are being laid out across the short axis(where they are *way* too long) , and the machine goes out of bounds when attempting to cut.
The layout of the part in eCabinets will dictate how the part is run in Profile Modeler. Taking a cabinet back as an example, the width of the back will run parallel with the Y axis on your machine, the height of the back will run parallel with the X axis.
Depending on your needs, have you tried running through Control Nesting? You should be able to manipulate and rotate in Control Nesting to get the direction correct for you.
