CN v6.11 manual nest crash
Joe Soto
Post by Joe Soto »
Any time I manually nest and end up with an empty sheet THM crashes when I write cnc. Pop up says empty sheets will be removed and sheets renumbered. Screen grays out and after a few minutes says software has stopped and must be restarted.
As long as I leave one part on every sheet it writes correctly.
Tommy Wieler
Re: CN v6.11 manual nest crash
Post by Tommy Wieler »
Same here
Thomas strembitsky
Post by Thomas strembitsky »
I just had this happen to me today. i can't send crash logs from the cnc for whatever reason but i hope it gets resolved cause i don't know how to delete an empty sheet outside of nest
http://www.trueform.ca
CS43 cnc
Stuart Douglas
Post by Stuart Douglas »
Can confirm. Often when manually nesting, I will cut a part from the last sheet and try to paste it into a previous sheet. After navigating to the previous sheet, I can't paste the part. It seems intermittent, sometimes it works, sometimes it doesn't.
_____________
NVME SSM2HD 1TB NTFS
Clint Buechlein
Company Name: Thermwood Corp
Post by Clint Buechlein »
I see the same thing with the empty sheet. I'll pass the information along to the software engineers. Hopefully will have it corrected for next release.
Stuart Douglas wrote:Can confirm. Often when manually nesting, I will cut a part from the last sheet and try to paste it into a previous sheet. After navigating to the previous sheet, I can't paste the part. It seems intermittent, sometimes it works, sometimes it doesn't.
I haven't come across an issue specifically like this, but was seeing some odd scenarios after creating a sheet and scrolling through the sheets. Now I can't get that to reproduce. This is on my desktop PC, only thing I can think is that an update to my graphics card driver corrected the issue. Let me know if you can get the issue to be consistent.
Clint Buechlein
The empty sheet with a crash issue should be corrected with today's release of Control Nesting.
