First job in the nest, all cab numbers are correct. Second job in the nest, cabinet numbers carry on from where they left off in the first job. So if the first job has 30 cabinets for example, Cabinet one in the second job will be labeled 31. However, the "original" cabinet number is still correct on the label, just the new large number is incorrect.Clint Buechlein wrote:What was messed up about them?
Colored symbols on labels
Re: Colored symbols on labels
This will be how it functions. It takes the cabinets in order in the load screen and applies a number sequentially. This label is more for part sorting rather than job sorting. If the cabinets for each job started back at the cabinet number, you would have to read the job name to decide which job the part belongs to.Tommy Wieler wrote:First job in the nest, all cab numbers are correct. Second job in the nest, cabinet numbers carry on from where they left off in the first job. So if the first job has 30 cabinets for example, Cabinet one in the second job will be labeled 31. However, the "original" cabinet number is still correct on the label, just the new large number is incorrect.Clint Buechlein wrote:What was messed up about them?
I moved the numbers up a little, you can try the attached label to see if its better.Joe Soto wrote:My scanner reads it fine. The actual recut ID number is right at or slightly off the bottom edge of the label. But that might be a tracking problem with my printer.
- Attachments
- 30252_Address_CabNum_Recut_V2.zip
- (6.48 KiB) Downloaded 376 times
Thanks Clint, works good.
Tommy, FYI. Label cabinet numbers will not match actual cabinet numbers if you change the quantities at the control or have multiples of the same cabinet from a batch either.
