Hinge Placement
Chris B Campbell
Hinge Placement
Post by Chris B Campbell »
Hey All,
Standard 94.5" tall cabinet with full length door. 3 hinges required, I want to move the center hinge so it's not into the middle of an adjustable shelf. No problem go to Center hinge offset, input 6 and yeap hinge placement moves UP and out of the shelf's adjustable holes. Nice but not ideal.
What I want to do is move the hinge DOWN so it's below the adjustable shelf's holes, tried -6 that did not work it just repeated the previous movement. Is it even possible to offset the center hinge placement DOWN from center?
Chris
Re: Hinge Placement
Hi Chris
Using metric.
-100mm works for down and 100 moves up, works for me.
I can't think of why it wont let you, perhaps cabinet locks or opening locks?
Just thought.
Haven't tested but maybe distance between hinges?
Mark
Clint Buechlein
Company Name: Thermwood Corp
Re: Hinge Placement
Post by Clint Buechlein »
Chris,
The negative inset option should work as you are wanting it to, can you post the cabinet or shoot it to me in an email?
Chris B Campbell
Re: Hinge Placement
Figured it out... Like a lot of changes I needed to delete and re apply. Odd that it allowed me to move up from center then back without deleting the doors. Thanks for the replies, have a nice Fathers Day weekend,
Chris
