Drawbar not Working!
Terry Davis
- Company Name: Penn Laminates
The drawbar on our CS45-510 isn't pulling the tool holders in tight I can can grab the toolholder and wiggle it around. After the machine picked up a tool and started running i heard a vibrating sound and I immediately stopped it. The toolholder is clean and so is the cone, all pressures are normal.
- Clint Buechlein
Re: Drawbar not Working!
Terry,
Give the guys a call in service when you can. 1-800-221-3865, option 2.
Terry Davis
Will do, thank you!
Daunte Smith
- Company Name: Innovative Wood Worx
Did you find a resolution to this?
We had the opposite issue last week where the machine wouldn't let go of a tool despite multiple attempts. After after a combination of rebooting and multiple (failed) manual tool swaps the machine finally dropped the tool.
After inspection we found no damage or debris in, on or around the spindle or tool holder in question. I don't like when issues "magically" go away...
Michel Leblanc
- Company Name: Extreme Kitchens
We had this issue and turns out we had to modify the coordinates of where the tool was being picked up and dropped off. It wasnt going low enough so sometimes it would work then other times it didnt.
Our service company helped us with this in the end
